Sending Contacts via Bluetooth
5 replies · 46,127 views · Started 29 July 2009
Hi all,
Just got my N97 and so far so good apart from one thing.
I can't find where to send the contacts via bluetooth. On my old phone I could send them all to my hands free kit via bluetooth but I can't find this option on the N97 😡
Can anybody help ?
Graham
If I recall correctly, you have to click and hold the appropriate contact. This will bring up a menu which includes the option to send via different means.
Contacts > Select contact (i.e, John Smith) > Select right hand (details) tab at the top of the screen > Options > Send business card > Via message/Via e-mail/Via Bluetooth
Graham30 wrote:Hi all,
Can anybody help ?
Graham
Hi. :hello:
It is very easy and simple to send all/some NOKIA contacts to other device via bluetooth.
First you can�t send by mobile bluetooth. Easy way is pc suite or OVI.
1- Clean/delete all my Samsung Galaxy contats
2- I select all NOKIA contacts in OVI (Ctrl +A).
3- File -> Export contacts �Choose location for contact export� for some folder (example� C:\Contacts�)
4- Active your target device bluetooth (I use Samsung Galaxy S3)
5- Click File Transfer �Send files to the (Samsung)phone �In Windows Bluetooth Device Control ( in my Win 7) �
Now you can enjoy and use it/them. 😊
Thank you, I think this kind of bluetooth headset is a good audio is also very good appearance design is very unique, scud bluetooth headset is a multifunctional wireless headset mobile, novel style, fashionable design, through the computer or other music broadcast equipment, at any time, any place to enjoy music trend
