Is it possible to put a logo on the front display of the 9210, like you can for most other Nokia's etc... ?
Steve
Steve
of course you can, i hope you mean operator logo?
give me your mobile no (with codes) & what u want written & i can make one & send u.
HyPeR
And if you mean the startUp logo i.e. 2hands, yip to that as well!
Download logomanager!
U will need to get a m-bus cable as well though!
Mmm... wounder if PSInt will add that to the messaging prog to change the startup logo? Ok guess that would be overkill!
how bout like a screensaver similar to the pc thing. instead of the blank black screen, some animation crap goes on.
can that be done?
Thanks guys, I've got logomanager somewhere from when i had a 7110 and 3210, must dig it out and the registration mail from them......
Don't fancy messing about findnig an m-bus cable tho, shame, would have thought it would have been possible throught the supplied cable or somehow through software in the phone, there are similar things available for Psion organisers i think.....
Any thoughts ?
Stephen
