http 403 error message
3 replies · 5,229 views · Started 02 August 2009
Mornin all
My husband has his N97 with vodafone (i'm on orange)
He keeps getting http 403 error message so ...
i've done a soft reset - which worked for a little while but then back to the error message.
and i've checked that the networks settings are definitely vodafone uk - i went through it all settings-connectivity-operator network blah blah but that didn't make any difference at all.
i've googled the error message and it seems to be peculiar to vodafone.
anyone else been having this problem ?
thanks
angiepea wrote:Mornin all
thanks
its just due to vidafone network errors, im not sur how to sort it but its nowt to do with the n97
The easy way to test this is try using wifi. If the error disappears on wifi then you at least know its your network's fault and not a broken phone.
