Seeking info on PIM functions in 3650
5 replies · 3,131 views · Started 06 March 2003
I'm considering getting a 3650 but am having trouble finding specific information on some of its built-in functions.
1) I presume the contact list is limited to 500 entries (or less depending on memory). Is this correct? Can this limit be exceeded with the addition of a larger memory card?
2) Can text information, such as mailing address, be associated with a contact?
3) Can contacts be organized into groups or categories, such as family, work associates, etc.?
4) Is the task/todo list limited to 30 entries? Can this number be increased with a larger memory card?
5) Can tasks/todo entries be categorized by something other than priority or due date? Alternatively, can you have more than one todo list, say one for work projects, one for home projects, etc.?
6) Is there any existing software than can be downloaded onto the phone that will provide the features discussed above, by either enhancing the built-in PIM applications, or alternatively, bypass the built-in PIM application with a new one. To be usefull, it must be able to synch with Outlook.
All help appreciated.
[quote="StevenT"]1) I presume the contact list is limited to 500 entries (or less depending on memory). Is this correct? Can this limit be exceeded with the addition of a larger memory card?[/quote]
There is NO limit except phone memory. In 7650 (that has 4MB) you can easily have over 2000 contacts.
[quote="StevenT"]2) Can text information, such as mailing address, be associated with a contact?[/quote]
Yes, as many as you like. e-mail addresses. anything.
[quote="StevenT"]3) Can contacts be organized into groups or categories, such as family, work associates, etc.?[/quote]
Yes. As many categories as you like.
[quote="StevenT"]4) Is the task/todo list limited to 30 entries? Can this number be increased with a larger memory card?[/quote]
No, there is no limit.
[quote="StevenT"]5) Can tasks/todo entries be categorized by something other than priority or due date? Alternatively, can you have more than one todo list, say one for work projects, one for home projects, etc.?[/quote]
No, that is not possible staight out of package. Get some program to do that. 😃
[quote="StevenT"]6) Is there any existing software than can be downloaded onto the phone that will provide the features discussed above, by either enhancing the built-in PIM applications, or alternatively, bypass the built-in PIM application with a new one. To be usefull, it must be able to synch with Outlook.[/quote]
There are many different programs that do those things, check the series 60 news section for programs.
http://www.allaboutsymbian.com/phpBB2/viewforum.php?f=15
Thanks, that's all good news. I'm that much closer to getting a 3650. I only need to find some software to expand its todo list capabilities. Any suggestions?
(just adding to this)
Its like a database.. for each person you define the labels used on each category and then put the data in.. Very advanced.
[quote="JyriK"]
[/quote]
Do they sync with outlook categories? I havnt tried till now but in the 9210 the categories did not sync.. groups in any nokia phone as far as I know are for personalization and setting ringing tones or messaging lists.. but do not sync with outlook as categories...
[quote="StevenT"]Thanks, that's all good news. I'm that much closer to getting a 3650. I only need to find some software to expand its todo list capabilities. Any suggestions?[/quote]
check here for alternate todos and reminder apps
- http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=60Series&jid=53XXBXX6B94DBD374696145C228FF643&platformId=4&productType=2&productId=51497&sectionId=0&catalog=20
-http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=60Series&jid=53XXBXX6B94DBD374696145C228FF643&platformId=4&productType=2&productId=50262&sectionId=0&catalog=20
- http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=60Series&jid=53XXBXX6B94DBD374696145C228FF643&platformId=4&productType=2&productId=50694&sectionId=0&catalog=20
Today views
- http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=60Series&jid=53XXBXX6B94DBD374696145C228FF643&platformId=4&productType=2&productId=35005&sectionId=0&catalog=20
- http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=60Series&jid=53XXBXX6B94DBD374696145C228FF643&platformId=4&productType=2&productId=56364&sectionId=0&catalog=20
-http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=60Series&jid=53XXBXX6B94DBD374696145C228FF643&platformId=4&productType=2&productId=52559&sectionId=0&catalog=20
seems like the forum doesnt auto-shorten the URL.. sorry if this post looks like URL flooding :-?
