Certificate Error. Contact the application supplier
4 replies · 45,444 views · Started 03 August 2009
"Certificate Error. Contact the application supplier�
Does anyone know how i can fix this error, i was trying to install some applications, it has been said those applications work for N97. anyone experience this sort of problem when they are trying to install applications? thanks for advice.😊
If I remember correctly, you need to sign these apps first before you can install them.
