v30.0.011 Firmware Thread
15 replies · 12,228 views · Started 04 August 2009
As there is no thread regarding the update on this forum yet, I just wanted to add one for the sake of completion 😊
[SIZE="4"]Inofficial Changes/Improvements/New features/Bugs noticed from v21.002 to v30.0.011
as by s60blog.com[/SIZE]
Standby screen:
  • When Music Player is operating, and seeing the track name on the screen, and then when one song ends and goes to the next track, the speed at which this happens has improved yet again from 21.002, although the noticeable change is not as much as from 20.149 to 21.002.
Call log, Contacts and calling function:
  • Calling speed (from standby screen to Contacts or Call Log) and transition to call/disconnected screens even faster than 21.002, is more than the instantaneous that I stated for the 21.002, it has improved yet again.
  • New menu option in the in-call menu to Send MMS during phone call.
  • Loudspeaker maximum volume has seemed to decreased
Maps:
  • Maps startup is now almost instantaneous, speed through all the Maps menus very fast, even faster than Maps 2.0
  • Switching to different views is very smooth and fast now, i.e. to Map 3D etc.
  • Maps version 2.0 week 39 remains the same, although the Maps is able to be upgraded to Ovi Maps 3.01 flawlessly
Music Player:
  • The biggest change is the equaliser improvements. There is a huge improvement in sound quality, even background sounds and other channels are more noticeable. The default equaliser settings are quite good. And bass is less crunchy than before.
  • Split-second delays now do not exist when pressing the volume keys to change between volume levels. In the past, there was some degree of delay, even running multiple applications now, that behaviour has been improved remarkably.
  • Freezes in the music player have not been evident to me yet in my days of usage with the new firmware . Which is a marked improvement in the functioning and stability of the music player. Screen tearing and slow speed for album art to appear is still present though.
Camera and Photos:
  • Biggest change is the reappearance of use of the volume keys to zoom while taking photos/recording video
  • Going into Details is faster than 21.002, almost instantaneous now
  • Scrolling speed through thumbnails is only minimally jerky now, also scrolling through photos at 100% view has improved in speed so it is now very smooth and almost instantaneous
  • *When going into menus in Camera, the speed is instantaneous
Video centre:
  • Logo has changed for the video centre in the menu
  • Appearance of video menu is different and seems to have inherited the newer N-series/E-series style simplified logos
  • Speed in the video centre is much improved and is almost instantaneous
  • Changing between volume levels in RealPlayer is instantaneous, fast-forward/rewind speed and resume of playback after these functions is improved and almost instantaneous. Sound quality appears to have been improved also.
Search:
  • Application has been upgraded from v4.08 to v4.10.0904
  • Logo has changed and is now reminiscent of the newer N-series/E-series simplified styling
  • Performance is faster and Yandex search service has been removed in favour of Live Search and Google (Note: this is for the APAC variant, will vary between different regions and specific countries)
Web:
  • Rendering of webpages has improved in speed since 21.002
  • Rotate Screen option speed is now almost instantaneous
  • Speed in Web options menu is now instantaneous
  • Loading of Minimap on side when scrolling down pages does not have pixelation anymore
Other:
  • Overall system speed has been improved so it is somewhat faster than 21.002
  • Scrolling in the Multimedia menu from one tab to another whilst multiple applications are running, has improved marginally in speed
  • Overall stability seems to also have been improved, have not had one crash or freeze where I have had to remove the phone battery. The slight freezes that have occurred, the phone has recovered from flawlessly.
it looks like the CPU speed has been increased to 434mhz, same as the n97, with the more recent firmware updates for the 5800. in fact since v20 forum nokia says the 5800 cpu speed is now 434mhz. 😃😉
RogerPodacter wrote:it looks like the CPU speed has been increased to 434mhz, same as the n97, with the more recent firmware updates for the 5800. in fact since v20 forum nokia says the 5800 cpu speed is now 434mhz. 😃😉
O rly? FTW! Still the same graphics adapter though 😞...
i updated my firmware from v20 to v30 a week ago & although the phone is much better regarding performance i do have a problem with the alarm clock. what ever time you set it always goes off 3 minutes afterwards. never had this problem before. i re-installed v30 firmware again on the weekend but i still have this problem. anyone else have the same? my 5800 is sim free, currently on O2
This is BS!
I have 2 XM5800 in hand and I have updated one of them to v30 and compared: the volume of the v30 speakers are much LOWER and ALOT less BASS also than the v21!
the speed has been improved and some bugfixes but the change thay did to the speakers is really BAD.
I wonder if someone could try to find a way to return the speakers settings to what they were at v21
Anyone know if this release is available yet in the UK?
My 5800 is currently using V21.0.025 & the OTA check still shows No Updates Available'
More curious than stressed about this...
Snooty
lord snooty wrote:Anyone know if this release is available yet in the UK?
Firmware is not actually limited by country, as I have an unbranded British Red product-code handset with V30FW installed.
Each mobile network decides which FW versions they support on their branded handsets. NSU only downloads FW approved for the (network specific) product-code.
You could consider de-branding (see sticky thread in N95 forum) but please be advised this invalidates the warranty with Nokia.
Peter Galbavy wrote:NOt 100% right. I have an unbranded red 5800 from the UK Nokia shop and there are no V.30 updates yet available.
Really? I stand corrected, which Product code is your handset?
I actually upgraded FW used Phoenix and the V30 package.
British Red was listed as a supported product in the V30 package, so I am surprised NSU doesn't offer it to you online...
Not sure I understand exactly how to get this update. When I check on my phone, it only shows the v21 update (I'm in the USA with AT&T). When I checked on Nokia's website, it says the same thing Does that mean it's not available for my North American version yet?
