[ASK] Shortcut keys to switch alternative keymaps on Nokia E63
7 replies · 11,234 views · Started 04 August 2009
Guys, I need a litle help here...
I just got my nokia E63 with english, russian and ukraina languages pack.
I've been figuring out how to quickly change the characters between latin and russian with shortcut keys.
When I was still using nokia 9300, it was easy to change the characters between russian and latin, I just pushed the both SHIFT keys and the characters will be changed between russian and latin.
But I can't figure it out on this E63, is there any of you who could help me out?
Some times I need to write both russian and english in one go.
Right now, if I should change the characters into russian from english or from english into russian, especially when on my internet browser or instant messaging, I should change the writing language from the main menu and that's really pain on the ass...
Sorry bro, I've tried ur suggestions with no luck. Pushing the buttons [ctrl] + [shift] or [ctrl] + [space] will only activate the predictive text input, not to change the writing language input.
But thanx anyway for ur concern, bro...
hi,bro
i got a friend who is using e61i,will it be the same?if it is,i can ask him for help
additionally,i want to know which input method u are using on ur phone,maybe u can change ur input method~~O(��_��)O~~
I don't know if it's the same or not with nokia E61.
My writing language input recently is in english (latin), if that's what you meant about...
Perhaps Nokia has deleted the shortcotkey to change the writing language input, because there isn't any information about it on the user's manual book.
Why did Nokia do that?
Well done, bro "smilehost"...
It miracly works to change the writing language input even on web browser mode also on ebuddy mode by pressing the buttons [ctrl]+[chr] then release the button [chr] only and keep pressing the [ctrl] button although it's a little bit difficult considering the small size of those buttons on E63.
Thank you, bro...
