where can i get a 3650 reflashed to version 2.50 or higher?
can anybody post a site that does it? or someone i can contact.... 😮
too lazy to search:)
i know this sounds stupid but a lot of shops in singapore and hong kong have the equipment to do it for you provided you buy your phone from them; otherwise they may charge you a small fee.
Go to nearest NSC (Nokia Service Centre) and ask for firmware upgrade.
It is free if you have warranty left. Otherwise costs something around 20euros ($20) + work.
Of course the NSC must have the new fw 😃 Maybe not all have, yet.
You can find the location of the NSC by going to www.nokia.com
do u lose ur data when u flash it? i think u do~
also... nokia australia says no such firmware update yet; as phone isn't even officially out here yet. hmph.
[quote="Seremify"]do u lose ur data when u flash it? i think u do[/quote]
Not usually.
But you should take a backup, incase something goes wrong.
im pretty sure i have warranty i just traded a panasonic gd87 for a brand new 3650,only problem version 1.34!!! is there a LOT of problems with this version? i dont think theres many NSC's in Illinois....
i may be wrong though im willing to pay i dont care...
Yes, the 1.34 fw is a lot buggy, as it is a test/beta firmware 😃
Get it upgraded to 2.50 as soon as possible.
yup I have to say the V1.34 is very buggy and some features are missing. Try to upgrade or get the one with V2.50 or higher. I had mine upgraded yesturday (I live in the Philippines) if it's done right no you don't lose your data. But just in case do make a back up like i did...
