It would be real cool to have some kind of a minimizer button that allows you to switch between programs runnngs by simply pressing a button (so its fast and easy). Its something like Magic Button for WM OS, but I want one for N97...
http://nokia-betalabs.blogspot.com/2009/07/mobimonster-system-status-v100-for.html Does this do what I want?
Some sort of minimizer software...like Magic Button for WM?
well double tap the menu button minimizes anything to the background and displays homescreen. Hold down menu button brings up running apps obviously.
One tip is say you have 4 app shortcuts on your homescreen and all 4 are running in the background, you can just click the main icon to go back to it. You dont have to long press menu button.
Lastly i believe there is a 1 click method of switching between running apps, kinda like alt + tab in windows. But i forget which app does this.
