Synching Outlook Email pc > p800
2 replies · 2,017 views · Started 07 March 2003
First Post Here!
I am considering buying a p800 and have a question, Can u sync the email in your outlook in box with the p800 so you can have current emails with you on your p800 which may not still be in your pop3 box.
Richard
Yep...the sync options allows this, then you can also have the option to have your e-mail settings as a separate account on the P800 so you can get e-mail on the move!
Thanks for your help. Off to orange shop credit card in hand!
Richard
