Microsoft Windows 3.1 on SymbianOS9
0 replies · 26,126 views · Started 09 August 2009
First Windows on Symbian S60
123526124893776762
DOWNLOAD DOXBox v0.72 for Symbian by kolijoco:
DOSBox_s60.zip
DOWNLOAD Windows 3.1 for Symbien:
Win3.1-on-s60_v1.1.rar
INSTALLATION GUIDE v1.1 (ENGLISH)
I. DOSBox v0.72 for Symbian
1. Unpack �DOSBox_s60.rar� archiwe to your Memory Card
2. Install ALL aplication from �Install� directory.
3. Try install DOSBox_Full.sisx
4. If show message: �Not enought memory� install �DOSBox_Slim.sisx� and replace previous version.
II. Windows 3.1 for Symbian (included Norton Commander 5)
1. Unpack �Win3.1-on-s60_v1.1.rar� archive to your Memory Card.
2. Run DOSBox.
III. To switch between Windows 3.1 and Norton Commander 5.
1. Go to �Data� directory on your Memory Card and find �dosbox.conf� file.
2. Edit file in notepad.
2.1 To run Windows 3.1
# Loader 1 � Windows 3.1
# mount a e:\Data\win31\ (To install more drivers)*
mount c e:\Data\
mount d e:\
c:
c:\Windows\win.com
# Loader 2 � Norton Commander 5.0
# mount c e:\Data\
# mount d e:\
# c:
# c:\nc\nc.exe
* TO install new drivers you need tu put Windows 3.1 installer files to e:\Data\win31 directory.
Edit �dosbox.conf� file and remove �#� in �mount a e:\Data\win31\� line.
2.2 Run Norton Commander 5
# mount c e:\Data\
# mount d e:\
# c:
# c:\Windows\win.com
mount c e:\Data\
mount d e:\
c:
c:\nc\nc.exe
2.3 Changed
Added MCGA (320�200) Driver
Added Win32s v1.30c with OLE
IV. Suggestions
1. To switch between the mouse and the keyboard press �Call� key.
2. Turn off automatic screen rotation, it may cause DOSBox close.
3. To change DOSBox allocated 2MB RAM edit line �memsize=2′ in file �e:\Data\dosbox.conf�.
If you have mobile with enough RAM memory (for example N82 or N95 8GB) you can try run Windows 95.
All you need:
1. Download Windows 95 Bootable (for PSP): Download
2. Unpack w95.img to �e:\dos\windows\� directory.
3. Edit autoexec line in e:\data\dosbox.conf file:
[autoexec]
# Lines in this section will be run at startup.
imgmount c e:\dos\windows\w95.img -t hdd -fs fat
boot -l c
4. Change memsize=2 in e:\data\dosbox.conf file to minimum 8.
5. Run DOSBox
Note:Not yet tried..because I don�t have n82 or n95�so please try and post your feedback
Download Windows 3.1(9.5 mb)
