Any ideas on how to conclusively ascertain if it is the Pop-port issues (hw/connector bad or cable bad) ? The original handsfree (wired) set no longer works, nor does the USB-connector cable (for PC conn). Beginning to wonder if it's really a cable issue or port issue. The local Nokia Support Centre has unimaginable queues. So wondering if there is any way to quickly ascertain problem type, at home.
thanks,
b
