9290 Internet Setup Help Needed
0 replies · 2,421 views · Started 14 August 2009
anybody still using a 9290?
I bought mine about 6 years ago and initially used the internet through my local ISP who had a dial-up number - it worked but was very slow.
I gave up on using the 9290 to access the internet a few years ago but now would like to try it again.
I no longer have a dedicated ISP just a DSL line from Qwest with internet connectivity.
my cell provider is AT&T.
can the 9290 be setup to access the internet using AT&T? I have an internet access plan from AT&T - it is a per use basis plan.
I have some of the essential info from AT&T like connection name and access number but I can't get it to connect.
AT&T tech support and Nokia tech support keep redirecting to each other and nobody seems to have the answers.
can you help?
