manually change 5800 screen orientation
1 replies · 4,337 views · Started 17 August 2009
I haven't figured out how to set the 5800 to always be in landscape mode.
With the n95 you just slide the font down, if flips into landscape, then you slide it back and it stays in landscape.
With the 5800 I can only get it in landscape by enabling the sensor, which means it'll jump between portrait and landscape. So how do i set always landscape?
