battey probs on new e71
1 replies · 4,004 views · Started 17 August 2009
i have a new nokia e71 and when i got it about a week ago it only took about 15 mins and said it was fully charged but my battey dont seem to last long at all.
today for instance
i played bejeweled for 2 mims made two call about 5 mins long each and my battery goes to half way .
ive turned of active standby to see if it improves tomorrow but i dont see why i should be needing to do that to get a good battery time.
my nokia is on uk orange
ive changed the product code to 0567045 wich is European uk
but cant get an update to firmware
currently
200.21.118
27-11-2008
rm 346
nokia e71 (344.02)
and body able to advise how to update or what could be wrong with battery
thanks
hi,
is it branded? i dont think the firmware would have something to with the battery.
where did u get ur phone?maybe the seller changed another battery which is of low quality for u. go and ask them to change u an original binding
if u want to upgrade the firmware, use NSS to change the code first and then upgrade it with NSU
Jerry.
