baconroll wrote:Well Drift I took your advice and went to the Nokia store and had a good play with the 5800. I must admit I was pleasantly surprised how easy it was to type on the phone with my fingers and just couldn't believe how loud those speakers were! At first I thought the phone was creaky everytime I tapped it but I soon realized that was the vibration feedback (hope this can be turned off somewhere). I was also pleased with the size of the phone - definately pocketable and easy to use with one hand. But - there was one thing about the phone that really put me off it and that was the 'double' tapping! I can't understand it. Coming from an iPhone I knew it was going to be a bit harder to get used to the tap process but I didn't realize how much it was going to annoy me. I browsed the phone on many menus and found myself tapping, waiting, tapping again several times. I guess it is something that I would get used to but it put me off the phone although I'm still contemplating buying it lol! I'll report back soon.
Ah, good. Yes, the vibration feedback can be turned off if you don't like it, and I've noticed if you press quite hard on something you don't have to double tap, but it's still certainly no iPhone.
Well, think about it for a while, I was a bit too quick to buy mine and now I'm regretting it and soon selling it on eBay. I'm either going for a BB Curve, a T-Mobile G2 or an iPhone 3G, but it's very likely I'll go for an iPhone 3G.
The problems I had with it were just small things that I couldn't stand putting up with for such a long time. These were:
1.) The keyboards - I hated the keyboard on it. If I want to type in portrait, I have to use the Alpha-Numeric keyboard, because the Full Screen QWERTY (which is what I want to use) only works in Landscape and the Mini QWERTYs require the stylus to operate them comfortably. Not only that, but I found the response on the Full Screen QWERTY keyboard very slow - I can't comfortably type from key to key without it switching keys instead of typing 2. I know it still does it on the iPhone, but not nearly to the same degree.
2.) The touchscreen. While it's not exactly a burden, if I have the choice to switch, I'm going to take it. I don't want to have to either double tap or push hard on the screen to get something to work. While I may accidentally open apps whilst changing pages on the iPhone, it's not as bad as waiting for things to open and having to push hard or double tap on the 5800.
3.) The graphics adapter. My 5800 came with a game called 'GlobalThunder Racing' or something. Anyway, it had the same graphics that an old tennis game for my Sony Ericsson K700i (from 2005) had, but the 5800 struggles with it, and that is a factor for me, because I like to play games when I'm stuck on the tube or the bus for a long time.
4.) Freezing. The phone keeps on freezing up on me for short periods of time and turning itself off. I don't know if it's just my 5800 that does this, but either way, quitting applications can be very annoying a lot of times, and the amount of times I've got it stuck on the black screen switching a picture from portrait to landscape is unreal.
5.) Doesn't tell me I have low battery until the very last minute. It will tell me I have low battery on my last 2 minutes of using the phone, and that's just having it in my pocket doing nothing. I recently flew to Los Angeles (not long after I got the 5800) and decided to watch a film on it on the plane. Sound quality was great through the Nokia headset, the visual experience was overall a nice one, it was all going great, until I finished the film, and it decided to not tell me I had low battery once. Instead, the film ended, I exited it and it said 'Battery empty' and turned off. I was quite annoyed about that...
6.) The interface. I would have thought after over 5 years of the same basic interface Nokia would have changed by now, especially for their first touchscreen phone. Nope, same boring Nokia interface I had on my 6230i and earlier phones. Using the phone really isn't a nice visual experience in any way whatsoever, and brings no originality to the phone visually.
7.) The width (or lack of it). While it may feel nice in one hand, I find it a lacking width a bit too much. This is a problem because it means we can only have 3 applications on each row, and the icons end up looking big and bulky. This also limits us to only have a reasonable sized QWERTY keyboard on landscape mode, and not on portrait (like the HTC Diamond and iPhone and a lot of other touchscreen phones).
8.) GPS. I do like the fact it has GPS... when the thing works. I have been having so much trouble getting it to find my position, I don't know if it's just my 5800 with all these problems or not, but it's not been so great for me.
Well, those were only my problems. If you did read all of it, sorry it was so long xD.
But I still stick by the good things I said, especially the camera, the camera is very impressive.
Like I said, they were only my problems with the phone. It's still a great simple phone, but it seems more like it should have been released at the end of 2006/beginning of 2007. I don't mean to defer you from buying it, I just want to make sure you don't buy it and find all these problems afterwords like I did.
But yeah, just have a good, long thing about it 😉.
