memory probleme
1 replies · 2,371 views · Started 19 August 2009
every time i try to read any software help it says insuffisant memory close certain applications and try again. my memory is: c:77,7mo e:6,2go and ram:75,0mo.
please i need your help
When does this happen . Can you give some examples ? Which Phone are you using ?
The amount of memory sounds ok . Maybe someone can give you a solution or a workaround , when you are more specific .
😊 Regards jApi NL
