I just updated to v12 from v11 on T-mobile after changing product code to 0570817 now stuck with white screen with nokia logo. Is there a way to reset or is device bricked?
Help!!!
Have you tried this?
1) Remove the battery to power the phone down.
2) Insert the battery, then open the keyboard, press and hold the Shift (bottom left), Spacebar and Backspace keys simultaneously whilst pressing the power button.
Should do a hard reset.
Hi M8.
Try removing the MicroSD Card when booting the device then once its on insert it. Thats what I have to do or mine stics on Nokia Splash screen.
Sometimes you need to remove the Sim as well to reset the phone.
Shite or what
thx guys it's booting up now phew! :icon14:
