Many thanks for those who commented 😉
Unregistered wrote:Hi Asri, Nice revue, thank you for that. Are you able to sync with Handbase? With my former E51, it was possible, but now with the 5800 xpress music, the sync doesn't work. Do you know why?
I'm use HanDBase desktop version 4 on my Ubuntu box using the latest Wine. And I dont sync my database, I copy them manually. Most of my database work are done on the phone tho 😊
Unregistered wrote:Why does it matter if the memory card is under the back cover? Just how often do you change the card? Mine has been in my E71 from the day I got it and I can't see any need to take it out.
I have 3 microSD card which I regularly swap and insert into the E52 :
- 8 GB card for songs and transferring files (no need to carry USD thumbdrive anymmore LOL!)
- 4 GB card for movies, videos
- 1 GB card for my documents (articles, ebooks)
All these are my usual suspects, everyday use. Hence, for me, accessing card slot easily is very important.
To each his very own 😉
Unregistered wrote:Geez, listen to all these people bagging Asri for simply stating his opinion of the phone!
I like the enthusiasm 😉
Tim2233 wrote:How to sync contacts callenders etc in E52 with my Macbook?
I expect (hope) that a new iSync plugin will be made available soon.Is it different to the e51 keyboard?
Yes, it's wider and has a different feel.
I like the keypad, but when clicking left/right on the direction button it's too easy to accidentally press the calendar and email buttons.
How does the home screen know that you aren't typing digits for a raw phonenumber?
It doesn't 😊 You just type the numbers, they appear as normal, but above the numbers is a list of contacts you are possibly looking for. Press send to dial the number or use the direction button to choose the contact.
I really like this phone, but it's not made as solidly as the E51, and the email app crashes constantly - desperately hoping for a firmware update to address this. Otherwise it's fantastic
Tim2233,
1. Many thanks for your assistance. In my opinion, E52 controller keys is better than E75's. I have no problem using the D-Pad, it's spaced correctly.
2. Smart-dial integrates itself with the built-in contact database. It will search the name corresponding to the keypad pressed in T9 style. So, if you want to search A.S.R.I, you just type 2, 7, 7, 4 😉
3. I used E51 before. Hardware-wise, E52 is better but the E51's strength is the darker colour and it looks indestructible while the E52 looks very luxurious and "bling-bling", you know what I mean... 😉
I agree. Nokia Messaging is still too rough for heavy use. I'll write separate article for that 😉
Anyway, If any of you guys are interested to buy new E52 Malaysian version, email me asri at i-symbian.com. I can get it at good price 😉
