tv viewing prob
4 replies · 3,693 views · Started 22 August 2009
i am able to watch good quality tv using skyfire and catchuptv.com via my free o2 web bolt on. The small problem i have is stopping the screen saver coming on. Does anyone know of a way to keep the screen active ?
james
Here's what I do.
Install "Best Profiles" & create a profile called TV. Make the profile so that the back light is always on or always on when attached to a charger.
When you want to watch TV all you need to do is switch to your new profile & the light will stay on for you.
Just remember to switch back to your usual profile so as not to drain your battery when you have finished.
Hope this helps.
