Free document viewer?
2 replies · 4,364 views · Started 23 August 2009
having recently upgraded from an N82 to an N97 i'm annoyed that you now have to pay for quickoffice just to view your office docs and pdfs. Is there any free software about that does the same job as just a viewer?
Viewing of the .doc's, .xls's and .ppt's is free.
If you want to edit them, you have to pay to upgrade.
PDF's on the other hand, you only get a short trial viewer (Adobe LE) before you have to upgrade. On all other previous platforms, it was free.
well every time i try to open a file it says i do not have a license? how do i just view the files?
edit: ok i can view files on the original version that ships with the n97 but once i get the supposed free update i can no longer view. would this be why?
