ANY1 HAD THIS PROBLEM?????
3 replies · 2,207 views · Started 08 March 2003
when you click on the communicam button, the camera picture just shows a black screen in the camera viewer but when you take a picture it still takes one??..i have!!! i need to switch power/off and then back on to errect the problem. o well i guess its just a rebot signal, only happened about 2 times in 3 weeks though.
o yea and a qucik tip, convert your mp3s into mp4 and you can store like loads more of songs, not as good quality on speaker phone to show off but okay for your headphones.
s@Fe
The camera never gave me that problem...
I tried the Mpr/4 trick before, but for some reason it doesn't play or it just sounds like it's under water.
I also had this problem. I posted it two weeks ago.
I see the SE logo in viewer but the photo is taken ok.
It happened after copying files or the internet is on, so I think the phone memory is too full to show the correct motive in viewer. After switching off an on the memory is empty and it works correct.
Maybe this is away with the firmware update in april.
Ciao
Christian
Use goldwave to encode your mp3's to wav files using the GSM codec. You end up with fairly small filesizes, but the best thing is you can use the files as your ringtones, with mp3's you cant.
