I reset my n97 after installing v12, i then tried to resync with ovi suite 2, and everything synced except the contacts, i couldnt even drag to the phone, It turns out that the ovi contacts 1.2 i downloaded as part of the sw update was the culprit, remove it and the contacts sync fine. Any solution to this, if i reinstall it the syncing goes through the motions but no new contacts are synced or amended.
