animated wallpaper
2 replies · 4,650 views · Started 24 August 2009
hi folks ,new member here looking for some advice if possible,
I have just recently purchased the N95 and loving it ,however with me being a sony ericsson user for the last few years i am still finding my way with it ,my problem is that i have animated pictures in my phone that i would like to use as wallpaper ,i can view these in my gallery ok but when i select as wallpaper the animation does not work ,i did ask a friend who has the n95 also, he said i may need to install a certain programme for this to work ,can anyone help me out ,where to find such a programme and how to install it onto my phone ,
any help would be greatly appreciated , Ralfie
The best I can tell you is to go to ownskin.com. They offer a animated wallpaper feature which I have not been able to successfully use on N95 8GB. Maybe you will have better luck. If not you can use the theme feature which will allow you to create animated themes. This always works for me although a bit more indepth, but definitely worth it for the animation.
MobileOne wrote:The best I can tell you is to go to ownskin.com. They offer a animated wallpaper feature which I have not been able to successfully use on N95 8GB. Maybe you will have better luck. If not you can use the theme feature which will allow you to create animated themes. This always works for me although a bit more indepth, but definitely worth it for the animation.
cheers for that mate i will give that a go.
thanks again :icon14:
