Poker Tournament Timer?!
6 replies · 9,272 views · Started 24 August 2009
Anyone know where I can download one from?
Can't believe a flagship phone like this doesn't even come with a basic timer/stopwatch:icon13:
Cheers.
Would prefer a more dedicated App which allows settings for blinds etc so if anyone knows of anymore please share
Just a reminder....Time Machine is a flash application. When your screen times out and locks, the application S-T-O-P-S.
When you unlock the screen it will restart and then-and-only-then use the clock to determine if time has past.
Thus it is not very good as a countdown timer/alarm.
londoner888 wrote:Anyone know where I can download one from?
I had the same idea. After searching for a suitable app, i decided to write my own.
I't called 'green button timer' and can be found @ http://www.kangaderoo.nl
The application requires python runtime.
The primairy function is the poker timer, I added a basic stopwatch.
Here's a poker timer that I use: http://www.pokertimer.co.nr/
It's pretty good and it's free. When using it, you should set the phone to landscape mode before launching it. It works better in landscape and it does not seem to switch from portrait to landscape gracefully.
Maybe you find some information here.. many good poker articles and stories..
I don't think an online timer is a good choice tough because when you got a bad connection or something you can't go on probably.. It's never wrong to invest some money in a good product.. especially software.. Not everything that is free is good..
