F: drive behavior?
0 replies · 1,907 views · Started 25 August 2009
Has anyone else experienced the same problems that I have with inserting a micro-SD card into the F: drive?
When I go to format it, it says that other applications are using it--but other than the home page nothing else is running.
After formatting the card, the Messaging application resets itself to the C: drive instead of my E: drive and wants to reconfigure.
When I use File Manager to Remove the F: drive. It says to remove the drive, but then turns around and tells me that if I don't reinsert the card data will be lost.
Is it just me (or this Fujitsu 1 GB card)?
