Hi All,
After many attempts to upgrade to the new FW v400, I finally managed to do it. But now it poses a new problem. After upgrading, everytime I wanted to connect to the Wi-Fi network, my e90 will reboot itself😮
I have tried the hard reset, re-install the FW but nothing works. any solution anyone and please help. Thanks
Jeffrey
Your FW in corrupted
re-download the FW and install it again
Reinstall the Files and try again if not then goto the Nokia Priority showroom and if there is a problem then rectifiy your problem.
Wi-Fi
Switch off your phone, remove the battery after 2-3 minutes put the battery and switch on your mobile and then check 😊 Lets know if it helps :con?
cricfancy wrote:Hi,Switch off your phone, remove the battery after 2-3 minutes put the battery and switch on your mobile and then check 😊 Lets know if it helps :con?
I have done all the above and still having problems with wi-fi? Any other solutions please? Thanks
To distinguish between software (corrupted file ?) and hardware issues , I suppose to go the radical way :
1) remove the MemoryCard
2) try to make the Wifi connection
3) when problem still remains , do "Vulcan Death Grip" , see my Post here : http://www.allaboutsymbian.com/forum//forum/thread/81021/ .
4) when issue still remains it must be hardware disfunction .
😊 Regards jApi NL
Can you sign helloox2 for my nokia 5320 v4.13 IMIE 355740022913190 ..plzz i have tried many times asking peoples abt it but to no avail..and i have done hard reset on it and hoping it wont ever give thiz problem again ...
_________________
Diamond covers the needs of women drivers
