Post Your P800 Bugs Here!
3 replies · 2,544 views · Started 08 March 2003
Hi all, I've purchased this gem for about 2 weeks now, & I've found out a couple of bugs. As below:
1) When flip is closed, you would not be able to divert phone calls. When flip closed mode, in divert menu, once you click on the "ON" button, it does not allow you to key in the telephone number which you like as it will "automatically" go back to the (divert) menu.
2) No audio shortcuts when flip is closed either (quite a number of shortcuts unable to bring out when flip is closed)
3) When phone is in idle mode, after a certain time (1min), there'll be a flash of light (phone lights up). No ideas why is that so? Phone auto locks ??
Anyway, my phone firmware is R1D & Organiser firmware is R1G05.
Anyone with more bugs?? Please post it here. Thanks!
Yes # 3..when you leave it idle.. the light turns on to notify you that its been locked keyPad
Another few bugs,
[list]
1-Holdin down the power button when it crashes does not reset the phone. You have to hold it down from anything like 30 seconds to 3 minutes. I hate powerin it down the hard way :\
2-I put the Bird Ringtone as my sms-alert tone. It will not shup..even though im actually readin the sms..neither will pressing any button.. i have to wait till the bird ringtone ends or i manually put the phone on silent :\
[/list:u]
- sometimes after installing software over BT all my icons and programs are invisible - after off (on they are back again)
muh
