DO lexar memory sticks work in the p800 ?
8 replies · 2,595 views · Started 08 March 2003
I have a standard Memory stick from a sony MP3 player, but its too big for the phone. Is there a way i can use this 64K mem stick on the phone, via a convertor of something
No, you can only convert from Duo to Normal at
the moment. There is nothing that provides the
smaller mechanical interface of the Duo for
the normal MS.
Oh yes, there is a way. Just use a pair of big scissors and cut it in the right size.
It won't work, but it fits in the phone... :evil:
[quote="michis0806"]Oh yes, there is a way. Just use a pair of big scissors and cut it in the right size.
It won't work, but it fits in the phone... :evil:[/quote]
Na! Too much labor involved... I'd use a shoehorn to fit a memory stick into a P800! 😛ainting:
dunno about u guys but too me it seems to defeat the object of the memory sticks if they are not compatable with other sony devices.
[quote="Dinalli"]dunno about u guys but too me it seems to defeat the object of the memory sticks if they are not compatable with other sony devices.[/quote]
Duo (smaller in size) memory can fit into normal memory stick slots by using a converter but normal memory stick (full size) cannot be converted into Duo because there is no way to make it any smaller to fit into Duo sized slots!
Got it? :microwave:
