I am attempting to extract a string from a packet recieved by Bluetooth and display it on the screen using an information note.
For example the client (Nokia 7650) may recieve a packet:
CCCCCCMMMM...MMMM
Where CCCCCC identifies the type of message and M represents a character within the message (of which there are 32). The server process runs on a Windows PC and is written in Perl, I don't think that there is a problem with the generated packet as the command portion of the packet can be successfully decoded using:
if(iPacketBuffer.Left(6) == _L8("ABCDEF"😉)
// do something
where iPacketBuffer is defined as:
TBuf8<1024> iPacketBuffer;
The problem is in trying to extract the message portion, I am using the following code:
TPtrC8 message(iPacketBuffer.Mid(6, 32));
I then pass message onto a function defined as:
void Handler(const TDesC8 &aMessage)
TBuf<256> buffer;
buffer.Format(_L("%s"😉, aMessage.Ptr());
CEikonEnv::Static()->InfoWinL(buffer, KNullDesC);
The resultant information note simply containes 32 'box' characters.
I hope I have not overlooked something obvious, does anybody have any idea why this is the case?
Andrew
