Hi!...
i have Hantro 3.3 videomms app and Hip Cam App.. working together
is the best combination...
If you will record a short VideoMMS you can use Hantro app... about 10 seconds with audio
If you will record a large Video you can use HIP CAM app because you can set the size of file you want to record in kb. ... at medium quality and small size frame you can record arround 48 seconds of video with audio using a 300kb. size file. for example... and you have audio ON/OFF option in case you want video only and save memory for files.
And the most important thing for this combi Hantro/Hipcam is that HIP CAM don�t have a PLAY Option, so.. when you press a REPLAY option on HIPCAM after you record a video... the HIPCAM open the HANTRO App to play the video.. that�s nice.. and the videos are stored on the same folder.
So!.. by now we still don�t have the ONE only app for video with all the options.. HIP CAM don�t have the same quality using same options of Hantro... but HIP CAM can record more time if you want.. and that is important when you want to send a video attached to an email for example, you don�t have a 100kb. limit for that.
Hantro 3.3 still been the best for VideoMMS usage, good quality but for 10 seconds.
well.. this is my review 😃
by now i use both.. nice combo and not too much mem for that...
cya! 😃
