PC Suite for Nokia 7650
2 replies · 1,605 views · Started 08 March 2003
I've just installed the new version of PC suite (I'm using XP) and I can't get it to connect to my phone. I have an EPOX BT dongle (with the updated drivers so I can send photos from my phone to my PC).
I keep trying different COM ports in the connection manager but nothing. Is it something to do with mRouter?
Thanks.
Si.
Ive heard that the new mrouter is a little bit buggy. :-?
And only good PC suite is the first one, if you get it to work that is 😃
Hi
Yes new mRouter is buggy. I have problem that mRouter didn't see any other COM port except 1;5;IR. I did little bit of work and found that if you replace file "mRouterSerial.dll" in INTUWAVE DIRECTORY with the one from old PCSuite ,System (mRouter) will see all available COM ports.
