NSU doesnt identify my N97
4 replies · 6,257 views · Started 02 September 2009
Please help , NSU doesnt identify my n97 .. how do i upgrade my phone.
I tried upgrading through the software update in the cell , but i get a error saying no reply from server when it checkc for the update .
Please help
Akash
My desktop pc has this problem, I have no idea why, but the nokia installation messed up, and i've had a lot of hardware problems with it.
I solved it by switching to my laptop, which detects it fine!
akashkotak wrote:Please help , NSU doesnt identify my n97 .. how do i upgrade my phone.
Please help
Akash
OK... This is radical but it worked for me.
1. On your computer go to Control Panel > Programs and uninstall the following:-
Nokia PC Suite
Nokia Software Updater
PC Connectivity Solution
Nokia Connectivity Cable Driver
(Basically anything Nokia)
Download and install Nokia PC Suite Cleaner:-
http://europe.nokia.com/get-support-and-software/download-software/nokia-pc-suites/how-to/nokia-pc-suite-cleaner
Read instructions and run Cleaner.
Download and install either Nokia PC Suite 7.1.30.9 from here:-
http://europe.nokia.com/get-support-and-software/download-software/nokia-pc-suite/download#39
and Nokia Software Updater from here:-
http://europe.nokia.com/get-support-and-software/download-software/device-software-update
or you can download the latest OVI PC Suite (Beta) from here which includes NSU:-
http://betalabs.nokia.com/betas/view/nokia-ovi-suite-20
When asked to connect to any of these I would recommend the USB connection and select the connection type on your phone as PC Suite.
I know this sounds radical but it works.
Good luck! :icon14:
