[email protected] wrote:Yes, yes, yeeesss!Oh God... you're almost there!
Sorry... got carried away there.
Seriously though, you may like to download the latest version of OVI maps here:-
http://betalabs.nokia.com/betas/view/ovi-maps
Then go to C: and delete "cities" and "qf".
Then, and only then, with the phone outdoors and a clear view of the sky, start the Maps prog and select My location. Leave the phone for up to 5 mins to get an initial fix and download a map of the surrounding area.
Now you can connect your phone to OVI Suite or Nokia Map Loader and download the maps and voices you want.
On the phone Menu > Settings > Phone > Application settings > Positioning > Positioning server and then Positioning server use = Automatic. Access point = Contract internet or internet. Server address = supl.nokia.com
now you should get a lock a lot quicker. 😃
I thought there was something wrong with my menu's on Ovi Maps y'know. On previous versions, after it fired up and got going, and had connection to t'internet, to get to My Location, one had to press Options and select it from there.
So last night when I was in Jeddah, I kept pressin 'options' and the My Location just would not appear in the menu's, and I was thinking " I'm sure it used to be here...'
Until I pressed the red dot on the map.....d'oh. :redface::redface:
In Riyadh today, might delight you people with another screen shot, but to be honest, where we are in Riyadh, is a very barren landscape, and map screen shop will probably just be plain green , with nothing on it.....
