see title~
free is good. mmc support is good.
thanks
jeff.
see title~
thanks
jeff.
also could u guys please tell me how to install polyphonic ringtones without using wap? on the 6100 its just a matter of hooking it up to the nokia software!~ but on 3650 i can't find such a thing.. does that mean i can't use downloaded polyphonic midis from the7650.com?
You use Nokia PC Suite and either BT or IR if thats what your asking????
Nokia PC Suite
http://www.nokia.com/nokia/0,5184,5341,00.html
i have used that but i don't know how to install ringtones.. do i just copy them into the phones memory? i can't remember what it says as my dad took his laptop (and ir port) away and i can't have a look at the moment. but i tried clicking SEND FILE using win2k and ir port on my sister's PC to my phone and it had a system error... (on the phone)
just drop the sounds into the sounds folder digital or simple folder doesn't matter. It will recognize the sounds when you select it via the nokia profiles menu. Good luck.
Get Domi's excellent FExplorer.
http://www.gosymbian.com/
free & compact.
[quote="sahli"]just drop the sounds into the sounds folder digital or simple folder doesn't matter. It will recognize the sounds when you select it via the nokia profiles menu. Good luck.[/quote]
Thanks I tried it just then 😃
Good work!
Also thanks for the suggestion~ I'm getting FE now. Is it MMC compatible? I'll look on website..
