Call end & send key illumination inconsistency.
9 replies · 6,785 views · Started 04 September 2009
Hey all,
Just a quick question to all.
If you all could take a quick look at your call end key (red one) on your N97s when it is illuminated, is it illuminated evenly. I have just noticed that my call end key is strongly illuminated at the bottom but lightly illuminated at the top.
Just wondering if I've got a duff phone or that the keys irregular illumination is the same on everyone else's?
Many thanks
-Des:con?
Good old Nokia i spose. Was just concerned there as i have customised my N97 to hell and back as well as cramming it with all sorts of guff. Didnt fancy wiping it and sending it off for repair/replacement. Just looks a little naff is all. The point of these high end devices was attention to detail but thats probably just me :frown: oh well, thanks guys for taking the time to look!
-Des
Mines the same
Bet if you open the slide the cursor/mouse button whatever you want to call it is the same:mad😛oorly lit on the bottm left corner
Interesting, where did you purchase your handset from and when. Just wondering if it only effected early models. Bought mine in august.
-Des
Mine is slightly brighter at the bottom too ..... but hey ...... my lens is all good so i'm not complaining 😃
(e2save.com on orange received 26th June i think)
