SWITCH utility will not run N95
1 replies · 5,560 views · Started 05 September 2009
Up to Jan'09, I regularly sync my N95 with my E90. But suddenly the SWITCH application will not run; the N95 just flashes.
I updated the firmware in Dec'08 and again recently. SWITCH will work but after running restore from memory will not!
My reason for buying the N95 was as a smaller backup version of my brick, the E90.
Does anyone have a fix???
1) I suppose that you mean "Datatransfer" ? I think there might be a "Memory full" issue .
Clearing RAM is the first thing to try : just reboot (turn Off an On) the phone and try again . Anyway closing all applications before Transfer will be advisable .
2) Or a corrupted file , since right after firmware update it doesn't happen ? Reinstalling from the Memorycardbackup , reinstalles also the corrupted file again . In the case of firmwareupdate , or in case of hard reset , don't reinstall settings etc. from the MemorycardBackup , but reinstall everything manually . This workaround also saves the Memory ( C: and RAM) , since old , unused files are left away .
😊 Regards jApi NL
