does anyone know the settings for hotmail in the N97's email?
imap4 or pop3?
the incoming mail server?
outgoing mail server?
thanks
imap4 or pop3?
thanks
snuge wrote:does anyone know the settings for hotmail in the N97's email?imap4 or pop3?
thanks
Incoming e-mail
User name = Your hotmail address
Password = Your password
Incoming mail server = pop3.live.com
Access point in use = Default connection
Mailbox name = Whatever you want to call it
Mailbox type = POP3
Security = SSL/TLS
Port = Default
APOP secure login = Off
Outgoing e-mail
My e-mail address = Your e-mail address
User name = Your e-mail address
Outgoing e-mail server = smtp.live.com
Security = Start TLS
Port = Default
Hope this helps.
thanks mate that was spot on!
Another quickie what setting do i have to use if i want my email to notify me of new mail in the same way a text does. ive tried playing with the automatic retreval and i cant gte it to work? how often does the mail app serch for mail?
oops i over looked it i know the answer. sorry guys
snuge wrote:oops i over looked it i know the answer. sorry guys
Whats the answer? Because i could only ever get my e-mail to work the first time, every other time after that it gave me a stupid error where it wouldnt accept my password, even though it had originally, but if it could do it automatically it might work..
I tried auto retrieval but it didnt work
ok go to email settings then select your mailbox then go to automatic retrieval. disable email notifications and enable e mail retrieval. it then should give you a few more options, retrieval days, retrival houurs and retrival interval
Interesting. Just wondering if anyone has a Three branded handset and has manage to receive pushed emails using the nokia email application as apposed to Threes 3mail app. i only ask as i couldnt get it working and was wondering if its a three network thing or not.
-Des
I'm on 3 as well. Had nothing but problems with email, seems to work when it feels like, but not on any day with a 'y' in it...
Doesn't matter how I set it up, it always works fine at first, then randomly changes the settings. Don't know if it's a 3 thing or a Nokia thing.
Hoping the new 2.0 firmware solves a lot of these kind of problems - that is, if 3 release it! They were quick off the mark with v11 but v12 is nowhere to be found.
eccleshill wrote:I'm on 3 as well. Had nothing but problems with email, seems to work when it feels like, but not on any day with a 'y' in it...Doesn't matter how I set it up, it always works fine at first, then randomly changes the settings. Don't know if it's a 3 thing or a Nokia thing.
So, have you managed to get the inbuilt nokia messaging to push your emails to your handset or are you using 3mail.
I tried to set up my pop3 account with nokia messaging but i got a message from three saying i needed to set up an email account to start receiving emails. I managed to get 1 email pushed to my handset using nokia messaging but it just stopped working after that so i reverted back to Threes 3mail.
The only reason i ask is that Threes email software is ugly and totally user unfriendly when compared to nokias built in email editor.
It could be a Three firmware branding thing but im not sure. Tis a pain as i dont get 3G coverage at home so a wifi connection would be ideal but as im using 3mail, thats not an option.
-Des
