Hi all, just got my 97 on saturday
would like to ask, in app manager, i can see 2 files
RoadSyncInstaller - 902kb
and RoadSync - 1MB
can i just remove the installer file?
scrounging for C drive space 😞
and RoadSync - 1MB
How come your set comes with Roadsync?!?!?!
hold on to your panties 😉
i had it installed...heh. MFE and my company's exchange don't play nice with each other, so i switched to RS, which is like 1029309123123123 times better
anyone have a clue as to whether i can remove that file? don't want to risk removing it beforehand
edit: reformatted the entire thing and started installing stuff on the E drive instead. hope this leaves SOME space
I removed the installer file and Roadsynce is still working with no problems.
You'll find Roadsync doesn't like it if you update your firmware so you'll need to reinstall it then. It's worth keeping a copy of your server settings etc.
I reinstalled after upgrading to V12 and removed the installer file and it's working fine.
thanks! just uninstalled it, it shows 902kb, but doesnt look like i gained any space..
need to get into these system files and delete stuff!
