Hi in First :shakehand:
i had a Problem in my Nokia N95
it Was A gift from friend from UK
First of all when it came it didn't have Arabic language so i took it to the customer care here in Egypt and they gave me Arabic software (i need Arabic only for typing SMS for my friends)
Yesterday i connected it to Nokia PC Suite so it gave me that there is a new software update so i downloaded it and installed it (O2)
But Here Comes The Problem The Arabic support is Gone :dontknow:
so i kept searching for a solution for this but the only solution they gave to me is to change product code for arabic [0534856 ]
I have a Classic Nokia N95 Phone
so is it safe if i changed the product code and Reinstalled the software again
So when I was Searching i found a replay [http://www.allaboutsymbian.com/forum//forum/thread/72400/]
then i thought that before i upgrade it ask is that ok or not.
[SIZE="5"]So Now I Want To Change The Product Code From 0548021 to 0534856 [/SIZE]
[CENTER][SIZE="4"]Is That Is Safe Or Not PLZ HELP ME[/SIZE][/CENTER]
The Old SW That Have Arabic Support Is V 21.0.0.16
For My Mobile Info. Now After The Upgrade
SW Ver. 31.0.0.17
16-12-08
RM-159
Nokia N95 (65.01)
Original Product Code [0548021]
Made in Finland
Thanks You
Best Regards
