Monilink install on N97
3 replies · 3,035 views · Started 08 September 2009
Tried installing this online banking software today. For security its a WAP browser download and install only. Problem is it started to download and install fine but for some reason the file was corrupted (probably down to loss of signal) and tye progress bar gets stuck on half way. Ive tried to start the download again but it jumps straight to 50% and sticks. Monilink support say they dont know what to do to solve this. If i could find the file thats been partially downloaded and delete it I should be able to restart the download/install from scratch.
Any ideas??
I have exactly the same problem. No matter what I do install starts at just below 50% and then fails with a so called connection error.
Anyone any ideas where the partial file is as I cannot see it anywhere using x-plore.
Don't know if this will help you guys at all but its a response I got from Monilink when I asked if it would work with my handset.
Hello there,
The service is available with your handset. If you bypass the settings option by selecting continue wothout updating them it will be ok. When setting up the application too, please note that you will only be able to use the querty keyboard rather than, the touch screen. If you have any other questions please don't hesitate to contact me.
Regards
Pete Brown
MONILINK™ Customer Services
Free phone: 0808 168 29555
