WAP Error :(
4 replies · 1,951 views · Started 09 March 2003
HI!...
i am getting a new strange ERROR when i browse and click
to see one image on WAP...
On my WAP site for example.. when i click over a Background to
download and see it... it say:
�Error: Content exceeds device size limit (357000 bytes)�
No matter what image link i click .. same error...
So!.. what is that? ... 😞 .. the cache it�s empty... same error...
sometimes.. then the WAP is droped and closed the app 😞 ..
donno why this happend now.... never seen this error...
i have 3.16 ... but i have the WAP site a long time ago with the same images and links and never this happened ..
any idea?
any solution?
thanks! :cry:
What network you on mate?
We started getting this from some phones on our WAP site on Friday!!
I think it must be one of the networks restricing datasize or somink!
Bastards!
Let me know if you find the answer, I'l let you know too if I find out 😊
HI!...
yep i am getting this error from this friday too ... but my network operator is from Venezuela ... called DIGITEL ...
But may be is a new restriction for all GSM Operators...
i hope that is not true 😞
well !
thanks for your info.. almost i am not the only one with this error 😉
cya! 😃
HI!...
OK.. i got the solution 😃
i don�t know if it�s a BUGG on my Network Operator Config...
but... if i use the MMS Access Point for WAP ... i don�t have any problem with pictures download at any size 😃
only with the default Internet Access Point used for Wap too .. i get the ERROR ...
So!.. may be this people forgot to assign a limit the the MMS access point 😉
anyway i use that for WAP and it�s faster than the default one... 8)
cya! 😃
Try to do the same and check it..
Thanks for the tip!
If anyone complains about this error I'll know what to tell them 😊
Many thanks for this!
Will 😃
