How To Enter user NAme and Password in a E71 When Connecting to ISA Server
2 replies · 9,591 views · Started 09 September 2009
I can get my e71 to recognise my wire-less LAN at work.
It sees the Access Point and I know the WEP key.
The network can be defined and the Icon created is available in the Access Points folder of my e71.
However the ISA Server at work is configured for a User Name and Password authentication and I can not find anywhere on the e71 connection settings that allows me to set a username and password .
Does anyone know if this can be done?
I'm looking for soulution on the e71, rather than the ISA Server if possible.
I have spent days searching for a solution.
Please do not reply with "Ask your Tech Support people or Network Admin" because they don't know the answer either.
If you know please make the instructions simple to understand if possible.
Many Thanks
I can't give the straight answer to this issue . But I wonder if you tried playing with the somewhat hidden menu in Settings > Connect. > WLAN > Options > Avanced settings . Make a record of the original setting before changing anything !
Maybe .... ?
😊 Regards jApi NL
