Nokia 7650 - Bluetooth - mrouter
5 replies · 2,771 views · Started 09 March 2003
Please, please, please can ANYBODY help me?
I am going nuts here trying to get my Nokia 7650 connected to my pc via mrouter. For some reason it states:-
Cable COM1 Not connected
Cable COM3 Not connected
Unknown COM4 Not connected
Unknown COM5 Not connected
Unknown COM6 Not connected
Unknown COM7 Not connected
Infared Not connected
I have attempted to select one of the above to get connected but with no success.
I have tried a Google search in a quest for a solution but to no avail.
I have sent some data via BlueManager from my pc to my phone, but I can't get into PC Suite as it asks for my phone to be connected to the pc, hence mrouter (and its lack of connection).
I am in serious need of some bright spark to help me here, as I am not too hot on computers.
Thanks for your time.
Have you opened your bluetooth manager and doulbe clicked the serial connection?
Also tick the box on mrouter for the same IRQ that the bluetooth serial is using.
You may get an error when you double click the serial connection in bluetooth manager - but watch mrouter on your system try and you should see it connect.
Best
Will 😊
Sorry to sound like the complete novice that I am, but what the serial connection in Bluetooth Manager? I know what Manager is, but not Serial connection.
I assume it's here I'll see what IRQ it's using (as I don't know what that is either)
Thanks for helping.
I have to select com4, wait a second, then com5, then wait a second, and it will connect... when I'm lucky... if not, I must deselect all of them, wait a few seconds, then select com4, and after that, com5.... that's the only way...
