n95 Mac compatible?
1 replies · 5,571 views · Started 09 September 2009
Download the latest Mac client from Nokia called Nokia Multimedia Transfer, this will allow you you sync your phone with iMovie, iPhoto and iTunes. You can then transfer movies to the phone.
You can use the Nokia Device Browser which is a part of Nokia Multimedia Transfer to grab files from the phone or if the files are on your memory card connecting in Data mode should let you get the files that way.
The Nokia iSync plugin for N95 will allow iSync to work with iCal and Address book to your phone. I sync my contacts to Address book and my calendar to iCal and it works well. I really like the way the next couple of calendar events show on the display.
I purchased a 16GB memory card for my phone and slowly transferred 10GB of music onto it. The transfer is slow but I have had no problems using it.
I hope that helps.
Edit
I use the USB cable for transfer as it will be faster than Bluetooth and not drain the battery. This is also why I mentioned connecting in data mode .
