HBH-60 vs. HBH-15
3 replies · 2,246 views · Started 09 March 2003
I have an HBH-15 set that I bought with my T-68 (upgraded to T68i) and it works great! And now its working great with my P800, can anyone mension a reason or two why I should buy the new HBH-60 other than the size and looks reasons?
Thanks in advance :roll:
2 words: Way Better.. I had the HBH-15 a year ago then I moved up to the HBH-30 late last year. Now I got the HBH-60 the other two will be on the shelf for a while. Lighter and more discreet. The biggest difference is clearity.
I seem to be having a problem with getting the HBH-15 to work properly. Is there any trick that I need to know. They are paired buy when I pree the headset button to make a call I get a message saying "No sound detected".
Any ideas.
There is no trick in the HBH-15 operation vs any of the upgrades. When are you getting this error msg? When you try a voice command or try to answer the phone?
