What the Heck!!!! when I compile an sms message and attempt to send it I am met with 'not enough memory, delete something and try again' or something on those lines! I have to remove the battery from the phone and then go through a laborious process of re-installing the battery and adjusting the time and date etc etc, in order to send the message. This does not happen all of the time? what on earth can be wrong, do I need to have the phone upgraded to a newer software or something?Please if anyone can help?:con?:con?:con?:con?:con?
Nokia N9500 Communicator Freezing
It might be an memory problem e.g. RAM . Press menu scroll to the left side of the bar and see how many applications are open . Close a number of apps , using the delete button , and try again .
You allso can refresh the OS by taking the battery out > Back in > Press On . Now it is a little tricky . WAIT untill you see the reaching hands . Then press AND hold : Ctrl + Shift + I . Keep them pressed down untill the dialogue pops up . This might help also .
Don't do this as long as you see the big NOKIA letters . You might end up loosing your firmware doing wrong action after the popup dialogue ! Be carefull .
😊 Regards jApi NL
Great little topic.
And Nice work--thank you for sharing- for me this makes perfect sense though.
I am using nokia 9500 i know its old model of nokia but i satisfied with its performance.nice hand set
