I am curious as to why, on ovi maps, my phone seems to be always downloading over my 3.5g connection...
I know the app is only about 1mb, so obviously the maps are not pre loaded but is there a way to download the maps so that it is not always downloading over my 3.5g connection.
Also, with Google Maps, i presume the same applies (i haven't installed it yet). Is there a way to download the maps for this also...
thanks in advance
There is an application for the PC (and a Beta for Mac) called Nokia map loader. I think you can find a link on the OVI maps Page. There is no possibility to pre-download maps for Google maps.
Ok thanks...
Ovi map - cool, thanks
Nokia Maps - so does this mean that it will eat your bandwidth each time you use it... once you have visited and used a map of a certain area, is that map saved or is the cache wiped each time you use
thanks again for you reply
oo7ml wrote:Ok thanks...Ovi map - cool, thanks
Ovi Maps is the new name for Nokia Maps. Upgrade the version on your phone and use Map Loader to choose and download your maps and voices.
Apologies... i posted my last post incorrectly... it was supposed to say:
Google Maps - so does this mean that it will eat your bandwidth each time you use it... once you have visited and used a map of a certain area, is that map saved or is the cache wiped each time you use
Google maps does cache - but it caches to C:\ so will eat loads of precious memory...
[homer voice]Mmmm.... precious memory[/homer voice]
I've not installed it on my latest N97 for that very reason...
Bye bye google maps...
Sorry for going off topic here but why the hell would some one design a phone and only allow:
- less than 1% of it's storage capacity to the C drive
- 99% to the Storage (E) drive
(i really hope there is a good reason / answer for this)
thanks again for the replies guys
