Hi All,
Hoping that someone else has had this and can fix it quick!
My phone isn't alerting me when i get texts anymore, it's not untill i click messaging and then realise there are new texts in there, I had 4 texts spanning 5 hours yesterday and didnt get a single alert, ie 1 new message popping up down the bottom?!
Help me AAS, you're my only hope..
Hey
Look at the settings in
Settings>Phone>Notification lights> notification light> events notified
Zyyb wrote:Hi All,Hoping that someone else has had this and can fix it quick!
What firmware version are you on? Also, check your free RAM - might be worth clearing the web browser cache just in case...
Nope, all the boxes are still ticked...but thanks for playing..
I cant think of any option i've changed and it's not the profile as i've swtiched between 3..
celios wrote:What firmware version are you on? Also, check your free RAM - might be worth clearing the web browser cache just in case...
V12, hmm, does seem to be running a tad high @ 86%, i'll clear the cache then reset it..
Edit: Thanks Celios, that seems to have done it, i wouldnt have thought of clearing the cache
