I thought my Gprs connection settings was screwed. I called my network provider and told them about the prob so they let me reconfigure everything, so i did. Then I found out
Settings work. If I use the built in browser I was able to surf via GPRS but I use operah it gives me problems. I cant connect using operah anymore but can connect using the built in browser. I tried uninstalling then reinstalling again but I still get the same thing. But if I use broadband(via usb cable/IR/Bluetooth, operah can connect without any problems. Any suggestions?
One thing I noticed was that when I uninstalled it and reinstalled Operah, all the bookmarks were back again? Is there a way to totally uninstall making sure I have a very clean installation?
